Industry Solutions
What is Supply Chain Risk Management Process and How It Work
The supply chain risk management process identifies, assesses, and mitigates risks to boost resilience and ensure business continuity.
Lewis
You face many challenges in today’s global marketplace. Almost 80% of organizations have experienced at least one major supply chain disruption in the past year. Over the past two years, 11% of companies reported incidents linked to supply chain risks. The supply chain risk management process helps you identify, assess, and address these threats. By using supply chain risk management, you can improve business continuity and build supply chain resilience. This structured approach gives you the confidence to handle disruptions and adapt to changing conditions.
Key Steps in the Supply Chain Risk Management Process
The supply chain risk management process gives you a structured way to protect your business from disruptions. You can follow several key steps to identify, assess, and reduce risks. Many organizations use a risk assessment framework to guide their actions. These frameworks help you stay organized and focused as you manage threats to your supply chain.
Risk Identification
You start the supply chain risk management process by identifying risks that could affect your operations. This step helps you build a clear risk profile for every part of your supply chain. You need to look at both internal and external factors. Common sources of risk include poor supplier performance, demand planning complexity, global labor shortages, inflation, and cyber threats.
Tip: Mapping out your supply chain and assessing supplier stability can help you spot hidden risks early.
You can use several methods to identify risks:
Method of Risk IdentificationDescription
Financial RisksRisks related to the financial stability of suppliers and market fluctuations.
Geopolitical RisksRisks arising from political instability or changes in trade policies.
Environmental RisksRisks associated with environmental regulations and natural disasters.
Operational RisksRisks linked to internal processes and supply chain operations.
You should also consider the most frequent sources of risk in global supply chains:
  1. Poor supplier performance
  2. Demand planning complexity
  3. Global labor shortage
  4. Rising inflation
  5. Volatile global economy
  6. Complex regulatory environments
  7. Geopolitical risk
  8. Reputational risk
  9. Natural disasters and climate risk
  10. Cyber risk
Several risk assessment frameworks can guide you during this stage. For example, the Acquisition Security Framework (ASF), ISO 31000, ISO 27001, and the NIST Cybersecurity Framework (CSF) all provide structured approaches for identifying and managing risks.
Framework NameDescription
Acquisition Security Framework (ASF)Emphasizes structured approaches to manage risks in supply chains, consistent with ISO, NIST, and DHS guidelines.
ISO 31000Flexible framework that encourages organizations to implement risk management processes tailored to their needs.
ISO 27001Focuses on managing supplier information security risks, assessing data access and incident history.
NIST Cybersecurity Framework (CSF)Provides structured controls for evaluating a supplier’s cybersecurity preparedness across five key areas.
Risk Assessment
Once you identify risks, you need to assess their potential impact and likelihood. This risk assessment process helps you decide which threats need the most attention. You can use a risk assessment framework to make this step more effective.
Many organizations use quantitative tools to measure risk. These tools help you understand how likely a risk is to happen and how much damage it could cause. Some of the most common tools include:
Tool/MethodDescription
Monte Carlo SimulationModels various scenarios and shows the potential impact of different risk mitigation strategies.
Six Sigma Software ToolsProvides statistical analysis and risk modeling capabilities.
R and PythonUseful for custom simulations to evaluate complex supply chain risks.
Excel-based ToolsHelps create risk assessment dashboards and probability matrices.
Failure Mode and Effects Analysis (FMEA)Quantifies severity, occurrence, and detection to assess risks effectively.
You should involve stakeholders from different departments to get a complete view of each risk. After you collect data, use a risk prioritization matrix to rank risks by their likelihood and impact. This matrix helps you focus on the most serious threats first.
StepDescription
1Involve stakeholders to gather diverse expertise and perspectives for accurate risk assessments.
2Use a risk prioritization matrix to evaluate risks based on likelihood and potential impact.
3Map risks onto the matrix to categorize them into high, medium, or low priority.
4Regularly update the matrix to reflect new or evolving risks, ensuring focused risk management efforts.
Risk Mitigation
After you assess and prioritize risks, you need to take action to reduce their impact. This step in the supply chain risk management process is called risk mitigation. You can use several strategies to protect your supply chain.
StrategyDescription
Supply Chain MappingVisual representation of the supply chain to identify vulnerabilities and dependencies.
Weighted RankingPrioritizing risks based on their potential impact and likelihood.
Value at Risk (VaR) AssessmentQuantifying potential losses in the supply chain under different scenarios.
Supplier SegmentationCategorizing suppliers based on risk levels to manage them effectively.
DiversificationUsing multiple suppliers to reduce dependency on a single source.
Inventory Management AdjustmentsModifying inventory levels to buffer against supply disruptions.
Scenario PlanningPreparing for various potential future scenarios to enhance responsiveness.
Strong Supplier RelationshipsBuilding partnerships with suppliers to improve communication and collaboration during crises.
You can also diversify your supplier base to reduce the risk of regional disruptions. Adjusting inventory levels and building strong relationships with suppliers can help you respond quickly to unexpected events. Scenario planning prepares you for different types of disruptions, so you can act fast when problems arise.
To measure the success of your risk mitigation efforts, track key metrics such as key risk indicators (KRIs), risk control effectiveness, and incident frequency. These metrics show you how well your safeguards work and where you need to improve.
Note: Regularly review your risk management framework to keep up with new threats and changing business needs.
Risk Monitoring
You need to monitor risks continuously to keep your supply chain resilient. Risk monitoring helps you detect threats early and respond quickly. You can track events and incidents that might disrupt your supply chain, such as natural disasters or geopolitical conflicts. Real-time monitoring gives you visibility into suppliers, manufacturers, and activities across your network.
You can use advanced technologies to improve your risk monitoring process. These tools help you collect and analyze data from different sources. The table below shows common technologies used for real-time risk monitoring in supply chains:
TechnologyDescription
Data Analytics ToolsPredicts and prevents supply network interferences, alerts to possible machinery failures.
Internet of Things (IoT)Uses smart devices for real-time monitoring, providing up-to-date information on goods' condition.
Artificial IntelligenceAnalyzes large data sets to predict/manage risks, optimizes logistics routes, improves demand forecasts.
BlockchainRecords transactions on a secure ledger, verifies product authenticity, reduces fraud and errors.
You can set up dashboards to visualize risk indicators and track changes in real time. These dashboards help you spot trends and patterns that might signal a problem. You can also use alerts to notify your team when a risk reaches a critical level. By monitoring risks closely, you can make better decisions and protect your supply chain from unexpected disruptions.
Tip: Use real-time monitoring tools to gain visibility into every part of your supply chain. This approach helps you respond faster to threats and maintain business continuity.
Risk Review and Improvement
You need to review and improve your supply chain risk management process regularly. This step ensures your strategies stay effective as risks change over time. You should establish a policy that defines how often you review and update your risk management plan. Many organizations review their plans at least once a year, but you may need to do it more often if threats or business conditions change.
You should update your supply chain risk management plan when you see changes in threats, organizational structure, or environmental factors. Regular reviews help you identify gaps and weaknesses in your current process. You can then adjust your strategies to address new risks and improve your response.
  • Review your policies and procedures regularly.
  • Update your risk management plan as necessary.
  • Address changes in threats, business structure, or environment.
You can involve stakeholders from different departments in the review process. This approach gives you a broader perspective and helps you find better solutions. You can also use feedback from past incidents to improve your risk management strategies. By making continuous improvements, you keep your supply chain strong and ready for future challenges.
Note: Regular reviews and updates help you stay ahead of risks and maintain a resilient supply chain.
Common Risks Addressed by Supply Chain Risk Management Process
You face many types of supply chain risks in your daily operations. Supply chain risk management helps you identify and address these threats before they disrupt your business. Understanding the main risks allows you to build operational resilience and protect your organization from costly interruptions.
Operational Risks
Operational risks can stop your supply chain from running smoothly. You might see disruptions from raw material shortages, equipment failures, or labor shortages. For example, during the COVID-19 pandemic, meatpacking plants lost 25% of their production capacity because of worker absenteeism. If you cannot meet delivery targets, your company could lose millions in revenue and damage its reputation.
You need to watch for these common operational risks:
Operational RiskImpact on Supply Chain
Raw material shortagesDelays production, increases costs
Worker absenteeismReduces output, affects delivery
Equipment breakdownsStops production, causes delays
Poor supplier performanceMissed deadlines, quality issues
Supply chain risk management helps you track these risks and respond quickly. You can use real-time monitoring tools to spot problems early and keep your supply chain moving.
Financial Risks
Financial risks can have a huge impact on your bottom line. Natural disasters, trade disputes, and cyberattacks can lead to major losses. In 2019, 40 weather disasters each caused more than $1 billion in damage. Trade disputes can cost hundreds of billions. Cybersecurity breaches are common, with most supply chain experts reporting multiple incidents. The pandemic also caused revenue losses for two-thirds of companies, with some losing up to 20% of their income.
You should pay attention to these financial risks:
Financial RiskEstimated Cost Impact
Natural disasters$1 billion+ per event
Trade disputesHundreds of billions
Cybersecurity breachesMultiple incidents per company
Pandemic impacts6-20% revenue loss
Short disruptions3-5% of annual profits
Long-term disruptionsUp to 50% of annual profits
Supply chain risk management gives you tools to measure and reduce these risks. You can use insurance, diversify suppliers, and invest in cybersecurity to protect your finances.
Environmental Risks
Environmental risks are becoming more serious for supply chains. Climate-related disasters, such as hurricanes and floods, can damage factories and delay shipments. In 2023, climate disasters caused over $250 billion in global economic losses. By 2026, environmental risks could cost supply chains $120 billion. If climate disruption continues, global supply chains could lose up to $25 trillion by mid-century.
You need to prepare for these environmental risks:
  • Natural disasters like hurricanes and floods
  • Climate change impacts on transportation and production
  • Resource shortages due to environmental changes
Supply chain risk management helps you build strategies to handle these risks. You can use data analytics to predict weather events and adjust your operations. By planning ahead, you keep your supply chain strong and ready for future challenges.
Tip: Addressing all types of supply chain risks helps you maintain operational resilience and stay competitive.
Geopolitical Risks
You face geopolitical risks every time you manage a global supply chain. These risks can disrupt your operations and force you to adapt quickly. You need to understand how different events and policies affect your supply chain. Geopolitical risks often arise from sudden changes in government, conflict, or international relations. You must stay alert to these risks because they can impact trade routes, supplier reliability, and market access.
Here are some of the most significant geopolitical risks affecting supply chains today:
  • Armed conflict disrupts trade routes and regional supply networks. You see this in areas like the South China Sea and Eastern Europe.
  • Trade conflict leads to proposed tariffs. You may need to reassess your supply chain strategies, which can increase production costs.
  • Changing regulations force you to adapt quickly. New trade policies and environmental rules can cause unexpected disruptions.
  • Climate change risks bring extreme weather events. These can damage infrastructure and affect production, so you need to invest in resilient practices.
  • Future pandemics threaten labor forces and logistics. You must prepare robust contingency plans to handle these risks.
You should monitor these risks closely. You can use supply chain risk management tools to track changes and respond quickly. By staying informed, you reduce the impact of geopolitical risks on your business.
Tip: Build flexibility into your supply chain to handle sudden changes caused by geopolitical risks.
Cybersecurity Risks
You encounter cybersecurity risks every day in your supply chain network. These risks have grown rapidly as more companies rely on digital platforms and third-party vendors. Cybersecurity risks can lead to data breaches, loss of sensitive information, and disruption of operations. You need to protect your supply chain from these risks by using strong security measures.
Recent data shows how common cybersecurity risks have become:
Statistic DescriptionValue
Third-party breaches increase30% of breaches involve third-party (up from 15%)
Malicious packages in open source software512,847 malicious packages logged (156% increase year over year)
Growth of malicious threats in repositories1,300% increase from 2020 to 2023
Organizations experiencing supply chain attacksMore than 75% in the last year
You must pay attention to these risks because attackers often target weak links in your supply chain. You can reduce risks by vetting suppliers, updating software, and training employees. You should also use monitoring tools to detect threats early.
FineReport helps you manage cybersecurity risks by providing secure data integration and real-time monitoring. You can use FineReport’s dashboards to track incidents and analyze risk indicators. This approach keeps your supply chain safe and resilient against digital threats.
FineReport's Purchasing Dashboard
Practical Strategies and Tools for Supply Chain Risk Management Process
Risk Mapping and Prioritization
You need to map and prioritize risks to strengthen your supply chain risk management process. Start by collecting data about your suppliers, part numbers, and spending. You should identify key supplier relationships, including Tier 2 and Tier 3 suppliers. Mapping out transportation routes helps you spot vulnerabilities. Create a supplier risk index by assigning weighted scores to each supplier based on specific concerns. Analyze these risks and develop recommendations to address them.
Key Steps to Mapping a Supply ChainDescription
Gather dataSelect key supply chains to map, collect supplier data, part numbers, and spend.
Identify key supplier relationshipsUnderstand your suppliers’ suppliers (Tier 2 and 3 suppliers).
MapIdentify routings and transportation modes to reveal risks.
Create supplier risk indexDevelop a weighted risk score for each supplier based on specific concerns.
Analyze and actBrainstorm potential risks and develop recommendations to mitigate them.
Supply chain risk management software makes this process easier. You can use these tools to accelerate risk identification, improve mitigation, and simplify monitoring. The best software integrates data from different sources, provides real-time analytics, and visualizes complex information through interactive dashboards.
Supplier Diversification
Supplier diversification reduces your exposure to disruptions. You should work with multiple suppliers in different regions. This strategy protects you from geopolitical instability and natural disasters. A recent study found that 81% of manufacturers plan to use geographically diverse suppliers. Companies with regional diversification experience fewer supply chain disruptions than those relying on a single region.
Supply chain risk management software helps you segment suppliers and identify over-reliance on any single source. Many organizations now use dual-sourcing strategies, with 73% reporting progress in this area. You can track supplier performance and adjust your sourcing plans quickly using these digital tools.
Scenario Planning
Scenario planning prepares you for unexpected events. You need to identify potential scenarios that could impact your supply chain. Assess the possible effects on inventory, delivery, customer satisfaction, and costs. Develop strategies such as alternative suppliers and inventory adjustments. Regularly review and update your plans to adapt to changing risks.
Supply chain risk management software supports scenario planning by modeling different outcomes and providing actionable insights. You can use these platforms to engage key resources, analyze impacts, and create mitigation strategies. FineReport offers advanced visualization and real-time analytics, helping you build robust scenario plans and respond quickly to disruptions.
FineReport's Multiple Charts For Data Visualization
Technology Solutions with FineReport
You need advanced technology to strengthen your supply chain risk management process. Digital tools give you the power to track risks, analyze data, and make informed decisions quickly. FineReport stands out as a solution that brings clarity and control to your supply chain risk management efforts.
FineReport helps you visualize every stage of your supply chain. You can see real-time updates and track logistics from end to end. This visibility lets you spot risks early and respond before they disrupt your operations. FineReport’s dashboards consolidate data from multiple sources, making analysis easier and more accurate. You can use low-code features to integrate data across departments, breaking down silos and improving collaboration.
The table below shows how FineReport’s technology supports supply chain risk management:
FeatureBenefit
End-to-end visibilityAllows tracking of every logistics stage visually, enhancing risk awareness.
Real-time insightsProvides immediate data updates, facilitating timely decision-making.
Comprehensive data visualizationConsolidates data from multiple sources into a single dashboard for easier analysis.
Low-code functionalitySimplifies data integration, reducing silos and improving collaboration across departments.
Risk alertsUses AI to forecast trends and provide actionable recommendations based on real-time data.
You can set up risk alerts that use AI to forecast trends and recommend actions. This proactive approach helps you stay ahead of potential disruptions. FineReport’s low-code platform makes it easy for you to customize reports and dashboards, so you get the information you need without relying on IT specialists. By using FineReport, you improve your supply chain risk management and make smarter decisions faster.
FineReport's Multi Source Data Integration
Collaboration and Communication
You need strong collaboration and clear communication to manage supply chain risk effectively. Working with partners and suppliers helps you identify risks early and develop better solutions. Joint efforts allow you to assess risks in depth and create strategies tailored to your needs.
  • Early risk identification becomes possible when you and your partners share information.
  • Comprehensive risk assessment improves when you pool expertise and resources.
  • Enhanced resilience results from collaborative planning and shared strategies.
  • Innovative solutions emerge when teams work together to solve problems.
  • Continuous improvement happens when you maintain open communication and review risk scenarios regularly.
To build a successful supply chain risk management partnership, follow these steps:
  1. Start with you and your supplier’s risks. Identify areas that could affect your business and your supplier’s operations.
  2. Communicate constantly. Keep open channels with your suppliers to share updates and concerns.
  3. Develop a shared strategy. Work together to create a mitigation plan that considers different perspectives.
  4. Revisit your risk scenarios periodically. Update your strategies as new risks emerge.
  5. Leverage powerful technology and tools. Use platforms like FineReport for better visibility and predictive analytics.
You strengthen your supply chain risk management process when you collaborate and communicate effectively. This approach helps you build resilience and adapt to changing conditions.
Building a Supply Chain Risk Management Process
A strong supply chain risk management policy gives you a clear framework for protecting your business. You need to set guidelines that help everyone understand how to identify, assess, and respond to risks. This policy supports your efforts to keep operations running smoothly, even when challenges arise.
Establishing Risk Tolerance and Objectives
You start by defining your risk tolerance. This means deciding how much risk you can accept without harming your business, finances, or reputation. You do not need to eliminate every risk. Instead, you focus on keeping risks at levels that allow you to operate safely. You should identify both internal and external risks, then assess how likely they are to disrupt your supply chain. Your supply chain risk management policy should include objectives that improve resilience, ensure business continuity, and give you a competitive advantage. When you set clear goals, you help your team stay focused on what matters most.
  • Proactively identify, assess, and mitigate risks.
  • Maintain operations despite supplier or regulatory challenges.
  • Satisfy customers and shareholders through effective risk assessment.
Defining Roles and Responsibilities
Your supply chain risk management policy must outline who does what. Assign clear roles to team members so everyone knows their responsibilities. You need people to handle risk identification, assessment, mitigation, and monitoring. Compliance, ethical sourcing, and environmental considerations also require attention. When you define responsibilities, you make sure that each part of the policy gets the focus it needs. Use technology to support these roles. Real-time data and predictive analytics help your team respond quickly to new risks.
  • Risk identification: Recognize potential threats.
  • Assessment: Evaluate likelihood and impact.
  • Mitigation: Develop plans to reduce risks.
  • Monitoring: Track risks and measure effectiveness.
  • Use technology: Enhance visibility and responsiveness.
Policy Implementation and Communication
You need to communicate your supply chain risk management policy clearly to all stakeholders. Start by engaging stakeholders through meetings or surveys. Provide actionable plans with specific steps and timelines. Know your audience and tailor messages to different groups. Regular updates keep everyone informed about new risks and changes to mitigation strategies.
MethodDescription
Engage StakeholdersSeek input and address concerns to foster collaboration.
Provide Actionable PlansOutline steps, responsibilities, and timelines for managing risks.
Know Your AudienceTailor messages for different stakeholder groups.
Regular UpdatesKeep everyone informed about evolving risks and mitigation measures.
FineReport supports your supply chain risk management policy by providing real-time data, interactive dashboards, and predictive analytics. You can use these tools to improve communication, monitor risks, and make informed decisions.
FineReport's Combo Chart For Analysis
Implementing and Optimizing Supply Chain Risk Management Process
Integrating Risk Management into Daily Operations
You need to make risk management part of your daily supply chain activities. Many organizations face challenges when they try to do this. You must deal with complex supplier relationships, changing regulations, and the need for ongoing risk monitoring. The table below shows common challenges you may encounter:
ChallengeDescription
Need for a formal supply chain risk management programYou require a structured approach to manage risks effectively.
Complexity of third-party relationshipsManaging risks with many suppliers and partners adds layers of difficulty.
Compliance with evolving regulationsYou must keep up with new rules to avoid penalties and stay compliant.
Continuous monitoring and assessment of risksYou need to evaluate risks regularly to adapt to new threats and maintain supply chain integrity.
You should set up systems that allow you to monitor risks in real time. Regulations change often, so you must stay updated to avoid non-compliance issues. When you use dashboards and alerts, you can respond quickly to new risks and keep your supply chain running smoothly.
Fostering a Risk-Aware Culture
You build a strong supply chain by encouraging everyone to recognize and address risks. Training helps your team spot risks early and take action before problems grow. When you reward proactive behavior, you create a culture that values prevention over reaction. You should also recognize suppliers who share information and show resilience. This approach extends your risk-aware culture throughout your supply chain.
  • Empower employees to identify and mitigate risks.
  • Promote collaboration among team members and stakeholders.
  • Ensure a unified response to disruptions through standardized practices.
  • Encourage joint risk assessments with suppliers for a complete view of vulnerabilities.
  • Foster a proactive approach that boosts operational resilience and customer trust.
You can conduct joint risk assessments with key suppliers, set up standardized protocols, and share best practices across your industry. These steps help you respond to risks quickly and effectively.
Continuous Improvement with Data-Driven Insights
You improve your supply chain risk management by using data to guide your decisions. You should assess performance trends and monitor key performance indicators for risks. Analyzing supplier performance helps you detect inconsistencies and forecast disruptions. You can anticipate demand changes and spot inventory risks before they affect your business.
  • Monitor KPIs for potential risks.
  • Analyze supplier performance and detect inconsistencies.
  • Forecast supplier disruptions and delays.
  • Anticipate demand fluctuations and inventory risks.
  • Identify risks in logistics and transportation.
  • Optimize inventory levels to avoid stockouts and overstocking.
  • Enhance supplier selection and management.
  • Implement contingency plans for possible disruptions.
  • Use IoT devices and sensors for real-time data collection.
  • Develop dashboards to visualize supply chain performance.
  • Set up alert systems for early detection of risks.
  • Apply AI-driven risk alerts and early warning signals.
FineReport supports your efforts by providing real-time dashboards, automated alerts, and advanced analytics. You can visualize risks, monitor supply chain performance, and make data-driven decisions that keep your operations resilient.
FineReport's Supply Chain Control Tower Dashboard
You need a robust supply chain risk management process to protect your business from disruptions and build long-term success. When you use a structured supply chain risk management process, you increase resilience at every stage. This process helps you identify risks, assess threats, and act quickly. You gain supply chain resilience by making informed decisions and preparing for challenges. A strong supply chain risk management process gives you the ability to withstand and recover from disruptions. You minimize operational impacts and ensure continuity of supply. You also improve supply chain resilience by using real-time data and clear policies. When you focus on resilience, you support business continuity and gain a strategic advantage. FineReport helps you strengthen your supply chain risk management process and achieve greater supply chain resilience.
  • Supply chain risk management practices increase resilience and robustness.
  • Effective risk management ensures you can recover from disruptions and maintain business continuity.
  • Informed risk assessment supports supply chain resilience and strategic growth.
  • You minimize impacts from natural disasters and supplier failures, ensuring supply chain resilience.
project management reporting
Continue Reading About Supply Chain Risk Management Process
Supply Chain Risk Explained and Why it Matters Now
What is Supply Chain Visibility and Why Does It Matter
Supply Chain Analytics Explained and Its Importance
What is Predictive Analytics in Supply Chain Management
Understanding Supply Chain Analysis and How It Works
What is Supply Chain Automation and How Does It Work
Frequently asked questions
You use the supply chain risk management process to find, assess, and reduce risks in your supply chain. This process helps you keep your business running smoothly when problems arise.
Lewis
